Results 1 to 10 of 15
Thread: Is my pool/ AutoPilot setting OK?
    Saint Cloud, FL
    Default Re: Is my pool/ AutoPilot setting OK?
    The output is tied in to each power level, so the output is a %age of each level. THe higher the power level and output %age, the more cell wear.
    Pat
    NY
    I see. Thanks. The more I understand, the fewer questions I'll have later on. I do know how to change the power level and will do so as soon as I get more CYA. I have an approx. 22,000 gallon pool. How much CYA do I need to add to increase it from 40 to 60?
    As always, thanks!
    Sardian is offline ** No working email address ** Sardian 0
    Using the Bleach Calculator program which offers a CYA calculation. For a 22000 gal pool it would take 3 pounds 8 ounces to raise the from 40 to 60.
    It's a handy little program, it can be downloaded here at the forum.
    Russell
    Quote Originally Posted by poolbee
    As always, thanks!
    Mesa, AZ
    I can't comment about your question on cell life, but one advantage of running at a lower power level and a higher percentage is that you have a finer resolution for adjusting output level. When you run high power and low %, each % change is a big change. Also, with the lower power level and higher %, you are adding chlorine more continuously, resulting in a slightly more stable chlorine level.
    NY
    Let me say that I really appreciate all the help on this forum.
    Tomorrow I will be adding the additional CYA to the pool and then lowering the power level to 1(and increasing the output), and testing from there to get my FC around 3 instead of 5.
