Thread: Need Tips Cleaning Diving Board, and seats
    mbar's Avatar
    Ashland, PA
    Default Re: Need Tips Cleaning Diving Board, and seats
    When I had the top of my fiberglass pool re gel-coated this year, the guys cleaned the waterline with a very fine sand paper. It took the dirt right off - I know it may have taken a slight layer of gelcoat off, but the gelcoat is very thick. They left me some to use - it works really fast, and without any pressure it doesn't seem to hurt. I don't plan on doing this often, but what a time saver, and elbow saver. It may be something you want to try.
    Northeast PA
    Thanks for the feedback, guys. I tried the old-fashioned method of bleach and water. I purchased a couple of the scot-brite scouring sponges and a scrubbing brush at the local Wal-Mart and must say the results were quite dramatic. The steps and jacuzzi seats no longer have dirt marking the water line and the diving board looks like it was replaced, because it is bright white, the color it was supposed to be Thanks again for the feedback. Incidentally, the entire cleaning took less than 30 minutes, so I am quite impressed what great work a little brush does!
    John from Boston
