Help no instructions with my 6 way test kit from walmart
I went to walmart and bought a 5 or 6 way tester. It didn't come with instructions!!!!
"Add drops" on the individual bottles but do we have to shake up after adding?
There is a place to test yellow (CL and Br together) and Red to test PH. I have a green bottom that says alkalinity titrant and a white one that says cyanuric acid reagent. There is a empty clear squishy plastic bottle (says a measurement of a 7 and 14 lines on it. Also there is in a uncapped skinny skinny tube container that measures 30 to 100 that says c.a. view tube (PPM). Last but not least a fatter tube like container ... also has no cap that is about 4 times the sizes of the skinny one that measures 5ml to 25ml. Can someone save me a trip back to walmart
Re: Help no instructions with my 6 way test kit from walmart
Here's what I can remember since I just bought one of those 2 weeks ago:
Chlorine/Bromine - Add pool water to the chlorine side until you hit the mark near the top. Add 5 drops of the yellow capped reagent. With the cap on the tester, turn it upside down and right side up to mix. Compare the water color to the stated color chart on the tester.
PH - Add pool water to the PH side until you hit the mark near the top. Add 5 drops of the red capped reagent. With the cap on the tester, turn it upside down and right side up to mix. Compare the water color to the stated color chart on the tester.
Alkalinity - Add pool water to the 35 mL level in the largest tube. Add 5 drops of the green capped reagent (yes, I know there is 2, but one says 'Add 5 drops' and the other says something like "Drop by drop"). Swirl the mixture until its *pretty* green. Add the titrant (the other green capped bottle) and swirl after each drop. When it turns red, count the drops you used and multiply by 10 - this is your alkalinity reading.
Cyanuric Acid/Stabilizer/Conditioner - Add pool water to the 7 mL mark on the smaller plastic bottle. Add the white capped reagent to the 14mL mark. Shake for 30 seconds. Then put that mixture into the skinny tube drop by drop (or just slowly), until you can no longer see the black dot on the bottom. Then read the level on the side of the tube and this is your conditioner level.
Hope that helps. For as long as that took to type, somebody else will probably have replied.
IG 30,000 gal vinyl
This all looks right except on my kit it says to fill to 25ml line when testing alkalinity.
Thanks no1ford. I was hoping someone would check me against the real instructions. My post was strictly from memory, which has a distinguished history of letting me down.
IG 30,000 gal vinyl
I also left out the hardness test. I haven't done that one yet, so it wasn't front of mind.
Hardness (Calcium) - Add pool water to the 25 mL level in the largest tube. Add 5 drops of the blue capped bottle marked "Hardness Indicator" and swirl to mix. It should turn red if there is any hardness. Then add the titrant (the other blue capped bottle) and swirl after each drop. When it turns blue, count the drops you used and multiply by 10 - this is your calcium reading.
IG 30,000 gal vinyl
I have this same test, but when i do the hardness test, I put 5 dropd in, and it turns yellow, not red. What does this mean? Does it matter considering that my pool is a vinyl liner?
