Thread: Alkalinity with a vinyl liner
    csevel is offline Registered+ Thread Analyst csevel 0
    Cleveland, OH
    Default Alkalinity with a vinyl liner
    Is it okay to keep the alk in a vinyl liner at 130-140 if the PH has stayed consistant at 7.5?
    Claudia
    18' Echo Canyon A/G Pool by Artesian
    8500 gallons
    3/4hp Jacuzzi 2-speed pump - Cartridge Filter
    IL.
    Default Re: Alkalinity with a vinyl liner
    100-200 has been recommended by Ben as just fine with vinyl if PH is stable.
    Actually, 0 to 180 is fine with vinyl... You CAN go to 190 or 200, but you start pushing your luck and can get scaling. If you have calcium in your pool, it can start getting cloudy at that level. Normally, in vinyl, calcium can go to 500. But if Cal is 500 and TA is 200, I wouldn't bet against your water going cloudy.
    As for 130-140---GO SWIMMING and don't worry about it!
    My pool is fixin' to be one big cloud then. LOL!! My alk is 280 and my hardness is 450! UGH! I have some work to do...............
    I would agree. But the process is fairly simple:
    Lower pH with acid to 7.0-7.2 to yank down alk, aerate to raise pH without raising alk. Repeat until alk is OK. This is the "short" version of Ben's stickied process. But it's the same thing.
    When I need to do it, I have a sprayer that screws into the return instead of the eyeball. It's a fountain and it cost me all of $20--and it works very well. So does a crowd of boys splashing, or even leaving the pool uncovered with the return jet pointing near the surface.
  1. new liner, well water filled, rust stains + high total alkalinity
    By sspine in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 03-14-2012, 03:17 PM
  2. Wrinkled Vinyl Liner
    By rbposey in forum In-Ground Pool Construction and Repair
    Last Post: 08-31-2007, 12:42 PM
  3. Getting a New Vinyl Liner
    By Spensar in forum In-Ground Pool Construction and Repair
    Last Post: 06-18-2007, 10:36 AM
  4. SWG for Vinyl Liner
    By markeast in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-11-2006, 03:50 PM
  5. Concrete to Vinyl liner
    By Edward in forum In-Ground Pool Construction and Repair
    Last Post: 04-21-2006, 11:10 AM
