Results 1 to 10 of 18
Thread: Where is my chlorine going?
    Default Re: Where is my chlorine going?
    Phosphate testing seems to be the latest pool store scam to get people to buy expensive chemicals. Phosphate removal is a last ditch effort. Maybe one in a thousand pools requires it. Many of our members have a heart attack when they find their phosphates are high, but following our methods their pools stay clear, clean and sweet--WITHOUT removers. So why bother testing for them?
    You go through ALL the steps for clearing your pool first before you go to phosphates. This starts with proper chlorination, proper shocking, patience and persistence. If, after a couple of weeks of PROPER algae clearing techniques your pool is still cloudy, you look to other causes and treatments.
    Finally, after ALL of them have failed, you test and treat for phosphates. This is, as I said, one in a thousand.
    Respectfully, I suspect that if you follow the standards for chlorination established here, you won't have problems and you won't need phosphate removal chemicals--unless you are that one pool in a thousand.
    VOLDADDY is offline Lifetime Member Weir Watcher VOLDADDY 1 star
    vanman,
    I had the same issue you are having now when I opened my pool. You can look back at my thread entitled "Excessive bleach consumption" and see all of the information I was given. Carl hit it right on the head...you have got to hammer it with bleach. I did 3x a day to get to 15 ppm and it took almost 2 weeks before whatever alien life force that invaded my pool died off. Now I'm on cruise control and add a jug of bleach every 2 days, and my pool looks great. Good luck, as I know first hand how frustrating this can be. I tested when I got home from work and bumped to 15 ppm, then before bed and bumed to 15 ppm, and on the advice of others I would even add an extra jug about an hour later, then in the morning I would test again, bump to 15 ppm. If you are losing chlorine from the bedtime reading to early AM reading [before the sun hits it] then you have something you don't want in the water eating your bleach. Do you have any CC in your pool? The weird thing about mine was I had 0 CC.
    Dec 2005
    Lakewood, CO, USA.
    Voldaddy - How did your liner survive the barage of chlorine?
    So when you maintain this high chlorine level is your pool out of service for swimmers for 2 weeks then?
    Again what about your liner?
    I just found a small 1/4" cut in our 5 year old liner. When I went to the pool store to get patch glue the woman at the pool store told me to watch the Cl levels because too high will cause that. I have never ran with high Cl other than shock.
    gg
    "too high" depends on the level of CYA in your water--stabilizer. With none, vinyl can tolerate up to 15ppm of free chlorine. But with stabilizer slowing down the chlorine, you can go higher--see the Best Guess table for the shock levels--they apply to vinyl pools.
    Well my chlorine has been dropping but not to 0 it goes down to 1 & 2 and holds there that's a big improvement. Maybe what ever is causing the problem is just about gone.
    vanman2501
    I did a full test of the chemicals and found my ph dropped to 7.2 and my th went to 200 but is holding chlorine between 1 & 2.
    vanman2501
    With a cya level of 45, letting your chlorine level drop to 1-2 is not adequate to keep algae away. You have to maintain the cl between 3-6 all the time. If you let it drop below that, it is an open invitation to algae. I would shock it back up just to make sure that something isn't starting as a result of the low cl you have had.
    Your right my chlorine is too low but after shocking it the chlorine was dropping to 0 and now it drops to 1 & 2 so for me that's a big improvement. This morning it any dropped to 3 so it's getting better. I still don't what is causing the large chlorine consumption but it does seem to be getting better. at this rate it should be holding a good number by the end of the season. So far I have used three times the chlorine I used all last year.
    vanman250
    My pool is finally holding the chlorine level at 6. Since I opened my pool I have been dumping tons of chlorine in my pool and it would disappear then it started to rise a little every few days and now it's finally holding where it should. Thanks for all the help.
    vanman250
