Results 1 to 8 of 8
Thread: CC and Shocking
    jrv331 is offline Registered+ Thread Analyst jrv331 0
    Default CC and Shocking
    I know the general rule is to shock when the CC level is over .5, but with a level that low would you even notice a color change? Im using a Taylor kit and dont even think I'd see the change.
    John
    Default Re: CC and Shocking
    You are pretty close. The problem is if you run the 10ml test, you cannot tell if it's actually .5, or less. If you see NO pink tint at all, it's 0ppm. But if there's a hint of pink and one drop of reagent clears it, it could be anything from just over 0 to .5, but no more.
    A lot of us have found it to be very difficult to get that last bit out--and swim anyway. It can mean something--I had a very tiny but persistent bit of algae inside my drop-in steps that seemed to not be reachable even when FC was 15! This year I'm trying something else that seems to work.
    Remember, though, you CAN do the test with 25ml. Then each drop represents .2ppm, not .5ppm, so you can get a better feel if it's only 0 to .2ppm-if it's definitely less than .5 (.2 or .4ppm) then don't worry about it.
    Thanks for the response. How would I use the 25ml tube? How many drops of solution would I need to add?
    JOhn
    Sun Prairie, WI
    Quote Originally Posted by jrv331
    JOhn
    John,
    You will use the same amount of drops as indicated in the instructions, the only difference is that you will multiply the number of drops you counted by 0.2 instead of 0.5.
    I hope that makes sense.
    Edit: So, instead of 1 drop = 0.5, it will be 1 drop = 0.2
    ~Dr. Spike
    Pool: IG vinyl, heated, fully enclosed (dome)
    Shape: Grecian (rectangular)
    Size: 20'W x 40'L
    Depth: 4' / 8'
    Filter: Sand w/DE added
    Other: 6' Diving Board
    Maintenance: BBB! Ben's PS234 kit! Manual vacuum, brush, and Pool Buster Max CG Gold
    I think Im missing somethig here. With my current kit I just fill the vial to the marked lin then add the drops as instructed then compare to the pink on the chart. It goes from 1-5. For the CC test I add 5 more drops of a different solution then compare to the previous color. Im missing the part about .02 and .05 for multiplying. There is no multiplying in my kit - ist just compare the color after CC drops are added.
    John
    waterbear's Avatar
    St. Augustine, Fl
    John
    You are using the Taylor K-2005 which is a DPD test. the others were talking about the K-2006 which is an FAS-DPD titration test. With your kit if you see the color darken when you add reagent 3 you have CC. this kit really won't measure less than about 1 ppm CC so anything less will be subjective. If the color stays exactly the same then assume there is no CC, if it gets darker then you might want to shock.
    I was starting to wonder if I was doing something wrong. Thanks for the clarification.
    John
    Sun Prairie, WI
    Sorry for the confusion. Yes, I was talking about the FAS-DPD kit.
    ~Dr. Spike
    Size: 20'W x 40'L
    Depth: 4' / 8'
  1. Shocking
    By dagostafamily in forum Dealing with Algae & Slime
    Last Post: 04-29-2012, 05:49 PM
  2. Shocking
    By trilogy problems in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-21-2012, 11:15 PM
  3. Is shocking necessary?
    By cscannon in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-03-2006, 06:16 AM
  4. Shocking
    By jrv331 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-01-2006, 12:46 PM
  5. SWG and shocking
    By davebva in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-16-2006, 12:00 AM
