You are using the Taylor K-2005 which is a DPD test. the others were talking about the K-2006 which is an FAS-DPD titration test. With your kit if you see the color darken when you add reagent 3 you have CC. this kit really won't measure less than about 1 ppm CC so anything less will be subjective. If the color stays exactly the same then assume there is no CC, if it gets darker then you might want to shock.Originally Posted by jrv331
