Thread: Dimmer for pool light?
    Central Texas
    Default Dimmer for pool light?
    We moved into a house with a 10-15 year old 15,000 IG plaster pool that has a single Hayward light. It had never been connected so I did the connection and it actually worked. But it looks like it's probably a 500 watt lamp, pointed at the house. I connected it to a switch circuit that operated some floodlights, so it has two - three-way switches inside the house.
    I'd like to be able to dim it by adding a dimmer out at the junction box where I connected to the cord going down to the light. I'd set it to a lower brightness and then leave it. Do these lights dim okay without issues?
    TW
    graciec is offline Registered+ Thread Analyst graciec 0
    Talking Re: Dimmer for pool light?
    Yes. We have 2 lites ;500 Watts /each pentairs [I would call the "traditional" pool lites.] and they are on a dimmer with a remote {cool brother's [who wired our pool] idea}
    .......... works great!
    Long Island, NY
    Default Re: Dimmer for pool light?
    Lutron makes a great range of dimmers - HD has some. Make sure you get the right power - the 1000W is close, try to get more than that - ask an electrician for the right sizing.
    I have the Lutron Maestro all over my house, regular and 3-2way (typical cost $35 each)
    Patrick
  1. CFL Pool Light Conversion & can't seal American Products Pool Light
    By DrBAF in forum Pool Equipment & Operations
    Last Post: 09-11-2012, 11:09 PM
  2. pilot light won't light on pool heater
    By packerfan in forum Pool Equipment & Operations
    Last Post: 06-12-2010, 03:10 AM
  3. New Pool Light
    By Tredge in forum In-Ground Pool Construction and Repair
    Last Post: 09-05-2006, 10:37 PM
  4. Pool light out
    By KirstenHW in forum Pool Equipment & Operations
    Last Post: 06-22-2006, 03:48 PM
  5. Dimmer on pool light ?
    By Phillbo in forum In-Ground Pool Construction and Repair
    Last Post: 06-06-2006, 06:17 PM
