Results 1 to 3 of 3
Thread: Pristine Blue
    Default Pristine Blue
    My pool dealer has recommended using Pristine Blue instead of chlorine. Says it is more forgiving than chlorine and is a low chlorine product.
    Please tell me the pros & cons of using Pristine Blue. Thanks
    waterbear's Avatar
    St. Augustine, Fl
    Thumbs down Wouldn't recommend it.
    It is a copper based product that requires you run at least a .5ppm FC so there is residual sanitizer. You would have to use it in addition to chlorine!
    for the pros and cons of it read Ben's FAQ on metals here:
    http://www.poolforum.com/pf2/showthread.php?t=98
    My own feeling is that copper is going to cause problems and it is not as effective sanitizer as chlorine. I really don't want to take a chance with the health of my family. Do you?
    Default
    Thanks for your help. I read the article you suggested. Guess I don't need to use this start up kit that came with the pool.
    I used chlorine with my previous pool. Will stick with chlorine.
