Re: New Pool, should I go with chlorine
If you follow the simple rules, it won't turn out bad. You just have to stay on top of your water's condition.
That means daily chlorine and pH testing--and adjusting anything that's off target immediately. It means once-a-week testing of FC, CC, pH, T/A, CYA, and CH (if you have concrete/plaster).
You replace knowledge with guess work and use only what you need.
