test results
Hello, newbie here, I found this site here and have learned a great deal and want to try the BBB method. This is my first pool, so im new at this and needing of a little bit of advice. Pool is 15x30x52 10602gal. waterheight is 48" AG vinyl liner, filled with well water. I started out with the advice of the pool store and added 2 1lb granular shock 6 OZ algecide40 and 2 smart sticks (trichlor). Results after day 1 with taylor K-2005c kit
FC 5
TC 3
CC 2
PH 7
TA 130
CYA 0
I added 8 oz borax retested after 4 hrs not much change added 8 oz washing soda tested next day
FC 5
TC 5
CC 0
PH 7.2
TA 120
CYA 0
I then added 8 oz more of borax tested the next morning
FC 2 CH 70
TC 2
CC 0
PH 7.4
TA 130
CYA 0 with these numbers what should i keep my FC at and should i buy some cya or continue wtih the 5 lb bucket of trichlor from the pool store till its gone?
- You may not post replies
- You may not edit your posts
Forum Rules
