Re: Skimmer leaking after installed
I am so happy for you. You are well on you way. Any comments regarding chemicals I will leave to others. As for silicone, I would do the same on my own pool or that of close friends, just not on a customers pool. You do need to make sure you have sealed the gap between the face plate and the wall. I would run a bead around the sandwitch point of the faceplate, wall and skimmer. You need to prevent water leaking between wall and liner as well as water leaking on the outside of the pool. This will also help with any rust issues around the skimmer area down the road.
Enjoy, Dennis
