Results 1 to 10 of 17
Thread: Newbie needs advice....so confused
    mbar's Avatar
    Ashland, PA
    Default Re: Newbie needs advice....so confused
    If possible, get a metal sequesterer - you can find them anywhere that sells pool chemicals - some will say "stain and scale preventor", others will say metal out, or metal free. If not, I would still raise my chlorine up to 10, it will clear up your water and not let any algae take over. Usually cloudy water means something is starting. If you can find stabalizer (cya) go ahead and put it in your pool, use a third of what they say, and don't test for it for a week - it takes that much time for it to show up sometime. Keeping the puck in the skimmer will give you some protected chlorine during sunlight, but you must test often as the sun will eat up the chlorine really fast without cya in the water, leaving you open for the algae. Consistancy is the most important thing. I would add a gal of bleach every hour or so till you reach 10 (which will take you all day). Then make sure after sundown you check and add bleach till you hit 10, and again before you go to sleep. The chlorine will continue to go down if it is fighting something even after the sun goes down. That is the way you can know that the algae is gone - the chlorine will hold overnight (no sun to eat the chlorine). After you hold your chlorine overinght, then you can let the chlorine drop to the level according to the cya.
    1. Put puck in skimmer
    2. Add bleach (not in skimmer) at return jets 1 jug per hour till you reach 10ppm
    3.backwash filter
    4. Add cya
    5. test often, taking chlorine up to 10ppm
    6. Keep filter running 24/7
    7. Have patience! Your water will clear!
    Northeast PA
    AndieP is offline Registered+ Thread Analyst AndieP 0
    Jul 2006
    Oklahoma
    Thanks again Marie for mapping it out for me step by step.
    I went to get bleach and pucks to start putting some stabilizer in the water but all Walmart had was HTH pucks that had copper added in them as an algaecide. Do I want that? I am trying to get away from putting copper in the water not add more. Are there pucks that don't have copper in them? I am thinking I might be better off to just order some stabilizer online.
    I also decided I would check my calcium level since you asked about it earlier.....I tested it twice and both times came up with 100! The pool dealer kept telling me my calcium level was fine ....isn't 100 too low for a concete/plaster pool (which appears to have been painted too before we moved here)?
    I haven't added anything yet b/c I just today had a chance to go get bleach and we are also dealing with trying to find a leak
    Do I need to increase the calcium before adding bleach/stabilizer?
    Honesdale PA
    If you go the puck route just be aware that I've seen containers at Sam's Club that were $10 apart in price for 40#, one said 'multi-use' or something like that and the other didn't. Cheaper didn't. Ingredients lists were the same...no mention of copper but I suspect the multi-use had it.
    Jul 2006
    Oklahoma
    The ones I saw today also said "multi-use" or something like that and had copper listed in the ingredients. I didn't get them. I was just going to use them to put some stabilizer in the water since I can't find any cyanuric acid here. (Small town pool place hour away) Would it be better to just order stabilizer online instead of messing with the pucks?
    mbar's Avatar
    Ashland, PA
    Yes, order the stabalizer online - you can often find free shipping. I do a lot of my shopping online since I live in a small town too. You will also have to get some calcium in the water too. Walmart sometimes has calcium, or if you have a lowes, they carry it. If not order that online too - you need between 200 and 400 for a gunite pool. Use enough to get you to 200, sometimes what it calls for will take you over 200! So I always go for less. You should add the bleach now, you don't have to wait.
    Northeast PA
    Jul 2006
    Oklahoma
    OK, I have officially started the conversion
    I am getting stabilizer, metal out, and calcium increaser. Yesterday I slowed added bleach to get to a level of 10.5 when I went to bed. This morning my numbers were as follows:
    FC 7.0
    CC 0
    PH 7.2
    TA 50
    CYA 0
    When I tried to test my calcium level it turned yellow instead of red. Do you know why it did this? My TA is dropping a bit...do I need to increase it?
    I added 2 more jugs of bleach to bring it back up to 10....I just keep it at 10 all day today and tonight, right?
    The water is clear...I can see the bottom easily but the deep end is just a bit hazy.
    Thanks again for your continued help.
    Jul 2006
    Oklahoma
    I am still going at this...water was clear yesterday, brought bleach up to 11 last night and this morning the water is cloudy. I added stabilizer Thursday night so I haven't checked the CYA level yet.
    My question now is do I continue to add the bleach at the return jet or should I walk around the pool with it or add it in the skimmer?
    Also where do you add baking soda and Borax? At the skimmer?
    Thanks!
