Re: Average Maintenance Costs?
s6skuzy
We are looking at purchasing a pool. Can anyone tell us what the average maintenance costs would be per month? We live in MI and would only use the pool on average 5 months out of the year (using heat when necessary). We are considering a 16X32 vinyl liner pool, in a south-facing yard. We are most interested in the rise in electrical and gas costs, chemical costs, and pool opening/closing costs. Thanks in advance...
Chemical - BBB Method should be less than $100-150 a season.
Electrical - Depends on the pump and whether the heater is a electric heat-pump or gas. A high-efficiency 1HP pump would probably be sufficient and that shouldn't cost more than $20/month to run.
Gas - $$$$$$, may want to consider an electric heat pump but that will not heat the water nearly as fast.
Open/Close - Opening the pool is pretty simple, just labor-intensive but would cost between $150-$300 while the closing (in a freezing climate) is more involved and you probably want someone to do it at least the first time. The cost would be in the same window as an opening.
I would think most prohibitive are:
Upfront cost of construction and pool
Replacement liners every 5-10 years
Periodic mechanical/equipment failure of pump, plumbing, filter
Cost of running heater - gas, electric, etc
Outside of Philadelphia, PA
18' x 40' IG - 22K gallons
Sylvan Gunite Pool (1979)
Plaster re-done (1997)
