Closed Thread
Thread: IG Vinyl How to get out wrinke
    Pittsburgh, PA, USA.
    Default Re: IG Vinyl How to get out wrinkles
    Still looking for suggestions. Please ....
    I saw mention of a plunger - how does that work? the pool store - install said I would have to completely drain for them to touch it -- and cost the same as installing a new liner. (They also said no-one takes them up on fixing wrinkls -- wonder why?)
    Dothan Alabama
    Default Re: IG Vinyl How to get out wrinke
    We had wrinkles in the shallow end of our pool last year as a result of excessive rainfall soaking into the ground and floating the liner. After waiting a month or so to make sure the ground had plenty of time to dry out, we drained the pool until the shallow end was dry, putting a couple of sandbags in the corners to keep the liner from slipping once the weight of the water was off of it. Got on our hands and knees and slowly pushed, rubbed, slid, shoved, cajoled and cussed the liner back into position. We used a vacuum to hold the liner in position along the wall and then refilled the pool. It wasn't an easy or fun job by any means but it worked fine and the pool looks like new.
    You might check with your pool builder and see how much they would charge if you do the draining, help them with the liner placement and refill. If you can do the bulk of the time consuming work and they don't have to be there more than a couple of hours they may not charge much.
    Default Re: IG Vinyl How to get out wrinke -- solved!
    I bought a $1 plunger from the dollar store and got the wrinkles out. What I did was put the plunger next to the wrinkle go suction then pulled / slide the plunger back and got rid of all the wrinkles. Once I got the big part down -- I could easily smooth it out with my foot.
    So for $1 -- I save a few hundred.
Closed Thread
