Thread: Should I use sequestering agent?
    Amir is offline Registered+ Thread Analyst Amir 0
    Potomac, MD, USA.
    Question Should I use sequestering agent?
    I have rdish/brown stains from the clay/mud that washed in the pool. Water is clear now. Does sequestering agent help removing the stains - I don't know if they are metal stains. If so what kind and how to use. The pool is Gunite with one month old plaster.
    Thank you
    Amir
    mbar's Avatar
    Ashland, PA
    Default Re: Should I use sequestering agent?
    Crush up some vitamin C tablets, put them in a sock, and rub it on the stains. You can also use some ph down in a sock if you have it. If the stain goes away then it is a metal stain. If the stain stays the same then it is organic. If it is organic, take your chlorine up to shock levels and keep the pump running 24/7, brush the pool and they will eventually go away. Let me know if you have any other questions.
    Northeast PA
    Potomac, MD, USA.
    Thanks for the info. You basically want me use a mild acid? Last night I sprinkled some Cal Hypo (slow dissolving kind) on some of the areas and that seems to work. I will give the acid a try this week end and see if it helps any better.
    Regards
    Amir
    mbar's Avatar
    Ashland, PA
    If it comes up with the cal hypo then it is organic, and the chlorine will eventually remove them over time.
    Northeast PA
  1. Ascorbic acid treatment for stains, which sequestering agent to use?
    By MountainStone in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-10-2012, 09:33 PM
  2. False CYA Readings with metal-out or sequestering proucts
    By smallpooldad in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-08-2006, 02:14 PM
  3. Well Water: Why you DON'T shock BEFORE using Sequestering Agent
    By NWMNMom in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-09-2006, 06:27 PM
  4. Yes/No: Sequestering Agent. Switching from Pristine Blue to BBB.
    By les_smith in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-05-2006, 11:10 PM
  5. Sequestering agent
    By zelmo in forum In-Ground Pool Construction and Repair
    Last Post: 04-22-2006, 01:06 PM
