Re: Discrepancy between test kit and pool store results
Your test kit is not necessarily useless--but understanding that the OTO test kits are not precise to begin with, and you lose a little more accuracy each time you dilute. So a 7:1 dilution really is not accurate enough to act on. Once you get your algae problem cleared up and can let your Cl levels fall back down, the kit will be a lot more useful.
