Re: Discrepancy between test kit and pool store results
I poured a gallon of bleach into the pool last night, and this morning it still had a greenish tint.
I got the WalMart HTH 6-way kit, and I still can't tell what my TC is...when I put the 5 drops of OTO into my water sample, it turns a deep orange color, and then within a minute, bits of orange sort of coagulate and become suspended in the water.
While I'm working on the levels, do you think it's okay for the kids to go in?
Use one part pool water and one part distilled water. Mix well, test from that, and see if it registers at 5 or less. If so, then read your result and multiply by 2. Again, you're going to lose some accuracy each time you dilute, but without a dpd-fas test, that's the best you can do.
