Page 15 of 16 FirstFirst ... 5 13 14 15 16 LastLast
Results 141 to 150 of 155
Thread: My Dolphin: Now I'm getting rid of it
  1. #141
    Default Re: My Dolphin: Now I'm getting rid of it
    I, too, will sing a company's praises when they make a good product and treat me right. I have no beefs with PoolDrStore, because they did BETTER than they were required to when my PoolBuster's battery went south. How many here have gotten P/Bs because this member got one first and liked it?
    Likewise, SmartPool and Maytronics are getting it in reverse. That's their look-out. Nobody likes getting burned on a $5 or $30 item, but getting burned on a $1250 item is not good. Not good at all.
    Well, neither SmartPool nor Maytronics is responding to me.
    I have sent Maytronics the following eMail:
    Hello ***,
    I still haven't heard from you. I left a message with Rebecca at SmartPools but she did not return my call.
    My friend found it wouldn't climb his walls properly either. It just couldn't create enough suction to hold it to the walls.
    I have noticed that other robotic cleaners CLEARLY have more suction—debris near them gets sucked up, not pushed aside (the way my Dolphin is pushing it aside).
    This is leading me to believe the WHOLE problem is somewhere in the pump/motor mechanism.
    I had asked SmartPool to check out why the unit was moving far slower than specifications say it should and they told me they would change the motor, but they didn't.
    My motor is STILL covered under the 3 year motor warranty, yet what is NOW clear to me, and should have been clear to SmartPool, is that the motor is probably the problem.
    Since no one is responding to me, I now am forced to assume that Maytronics and SmartPool have elected NOT to honor the warranty because neither of you are responding to me.
    I am making sure that all of my friends and acquaintances on-line are aware of this situation. Already, at least a half-dozen have stated they prefer to look at the other brands after hearing my history and similar histories from other members. I am noticing that people are now less concerned with the Dolphin's performance and more concerned that if there's a problem, SmartPool and, by implication, Maytronics, will not appropriately honor the warranty. And they are acting accordingly.
    I am now forced to waste time investigating relief from the court system. This is not a $50 coffee pot, this is a $1250 item that has not lasted the length of its warranty.
    Regretfully,
    Carl D*****
    So now I have to look into filing a small-claims suit against them. I have no idea how to do this, and I'm really, really annoyed by it, but I see no alternative. Any ideas?
    Dec 2005
    Austin, TX, USA.
    This is really unfortunate to hear. I have actually been somewhat satisfied with my new Dolphin. I have a freeform pool and it has seemed to work well for me these past several weeks. But, as you say, how can I keep something knowing that when I need product support the manufacturer won't be there. If Maytronics can't address this because of the current events in Israel they could at least send you an email indicating they will follow up as soon as reasonably possible.
    If you were in Texas I would recommend sending a DTPA (Deceptive Trade Practices Act) demand letter. The law here allows you to collect treble damages for warranty representations which are not fulfilled. I would suggest contacting your State Attorney General's office (web site) to research your rights of remedy.
    Best of luck to you. My unit will be returned this Saturday. I'm in the market now for another unit. I'm really thankful to see all the great folks on the forum stepping up with their reviews of alternatives.
  4. #144
    Skillset Guest
    Carl,
    Thanks for sharing the information on Maytronics/Smartpool. Sorry you are going through this. I'm in the market for a cleaner and will certainly steer away from these guys.
    Here some information that may help:
    Address:
    Smartpool
    575 Prospect St.
    Lakewood, NJ 08701
    (732)730-9880
    888.560.7665
    Here's an alternate e-mail I found: [email protected]
    Check out their BBB (Better Biz B - not the bleach system!) record http://www.trenton.bbb.org/nis/newse...21000017001936
    Their record does not appear that good. But you can try to file an online complaint with the BBB - this may jolt them into action.
    Marc
  5. #145
    Thanks! Smart Pool's record isn't so good, is it?
    The story gets funnier and more bizarre. This morning I got the following terse note from the Maytronics guy in Israel:
    Smart Pool have practically sworn that they are handling your problem.
    I find this truly amazing since Smart Pool hasn't talked to me or returned a phone call since June 29. I have the Dolphin, too, so they cannot be working on it. I can only conclude that Smart Pool is BS'ing Maytronics as well. After all, if they haven't contacted me in a month, and they don't have the unit, what can they POSSIBLY be handling?
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    My Brand new Dolphin is running a path back and forth in the same spot for 8 hours straight.
    It never did climb any walls....it Does sit at the edges and tries for 3 minutes.
    /sigh
    Some people have hobbies.....I have a pool.
  7. #147
    Quote Originally Posted by Tredge
    /sigh
    OUCH!!! At least I got almost 2 years of good performance out of mine before it did stuff like that.
    Try changing the program and starting it in another spot in the pool. Can you make it climb the walls using the joystick?
    Or contact the seller to get return it and get your money back. I'm luckier than you: For almost 2 years I thought my Dolphin was the best thing since sliced bread.
    duraleigh Guest
    I'm curious as to the Guiness world record for number of posts in one thread.....we must be gettin' close !!
  9. #149
    Middle Missouri
    True, but I hope the mods won't want close it! I'm very interested in how it turns out with CarlD and his battle with SmartPool/Maytronics. I'm subscribed and tuned-in.
    Jim
    16' x 32' / 15,400 gal / IG vinyl
    All testing done with
    PS234 test kit
  10. #150
    Well, I AM a mod (heh, heh) and I'm not looking to close it yet. If Ben asks me to I will, but I think that robotic cleaners are SUCH expensive items that these serious issues with one brand are important.
    I'm thinking if I don't get a positive resolution that this may be something to suggest for the Hall of Shame.
    Meanwhile, I'm finding the Blue Diamond works quite well, and is very thorough despite its eccentricities.
  1. Love my Dolphin!
    By poolbee in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-14-2014, 10:32 AM
  2. Dolphin M4
    By OlesIVaniv in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-05-2012, 05:42 PM
  3. First Dolphin run
    By brent.roberts in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-07-2011, 05:03 PM
  4. Dolphin tip
    Last Post: 06-22-2006, 07:21 PM
  5. Which Dolphin to get??
    By Greggk in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-30-2006, 11:35 AM
