Results 1 to 3 of 3
Thread: algae or metal??
    Holly Springs, NC
    Default algae or metal??
    I have written in a few times with questions about our above ground pool. We were finally looking like we were winning our battle with algae, then notice a few leaks, got frustrated with torential downpours washing dirt under the pool and into the pool and started over once the rain went away. We patched the leaks, put foam sheets under the pool (intex type), and started refilling. While filling we ran the water from the hose to a household sediment filtration unit then to the pool. We did this because we have well water and knew metals would be a problem. We decided to go ahead with the chemicals before it got completely full. We used shock plus from the pool store and notice a foamy look floating on it almost immediately. Within 15 min. our blue pool was green. My husband has gone to the store now for lots of bleach. My question is, does this sound like algae or metal. There does not seem to be anything sitting on the bottom of the pool but our "wanda the whale" vacuum had been running since water got above the intake part of the pump system. We are very frustrated and would appreciate any help possible. If this has already been addressed could you let me know the thread?
    Thanks,
    Alicia
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: algae or metal??
    If the pool turned green within minutes of shocking it I would suspect metals. Only having the water tested for metals will really tell you. You can add a dose of sequesterant according to directions on the bottle (I have used both Jack's Magic and Proteam Metal Magic with good results). If it is metals the color should disappear quickly...usually within 24 hours.
    Holly Springs, NC
    Thanks, we were afraid of that more than algae. We will have to see if we can find some of the Jack's Magic.
    I have not heard about anyone using the Aqua-chem chemicals (for the chemicals that may be needed with the BBB method). Are they inferior to other brands? If so which are the better ones to use.
    Alicia
  1. Are the stains from metal or algae?
    By tfrailey in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-25-2013, 02:55 PM
  2. Doheny's Metal Out
    By Jpc2003 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-13-2012, 02:22 PM
  3. Looking for name of old metal out product
    By TomB_pool in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-05-2012, 12:38 AM
  4. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  5. have a little metal what to do
    By gone01 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-15-2011, 08:15 PM
