Closed Thread
Results 1 to 10 of 11
Thread: steel vs polymer walls ?
    WI, USA.
    Default steel vs polymer walls ?
    One of the great frustrations in researching pools, is that you hear lots of bad advice. I am told that even the best galvanized walls will eventually rust, especially if they are scratched. Also considering that chlorine is corrosive, and that the resulting pits & surface irregularities can be hard on a liner,.....and I am leaning toward polymer. I have also heard that polymer is harder to set up. Any help from the pros on this issue?
    Default Re: steel vs polymer walls ?
    I am not a pro but am in the process of putting in a polymer walled pool Things seemed to go well. The panels were light. Everything fit well. I will let you know in 10 years. Pool has water in it, am just waiting on my electrical inspection to start the pump. Purchased the pool from poolwarehouse.com. They were pretty goood to deal with and matched any price I compared to. Chris
    Blding 18x36 IG vinyl rectangle with custom inpool steps, 22,000 gallons. Chris In Chapel Hill, NC [email protected]
    Dave,
    I live in Wisconsin and did a poly wall 5 years ago and 2 of my cousins have done the same brand. If you have any questions send me an email.
    gg
    Chris,
    Interested in your inpool steps. A standard set of fiberglass pool steps is the one of the biggest drawback IMHO to a vinyl pool. The inpool steps look so much better. I am considering a DIY pool. Did poolwarehouse assist you with steps? I found an article on the internet that detailed some of the construction details. Post a picture if you can.
    Eric
    Our polymer walls fit fine. We chose them because they wouldn't rust. Jo
    40,000 gal. DIY IG vinyl pool , Zodiac SWG, sand filter w/ Zeobrite, 3 Aqua Genie skimmers, 2 HP pump, pavers
    Madty is offline ** No working email address ** Thread Analyst Madty 0
    I used steel- they tend to move if installation is a little off without cracking- polymore will crack. Both are fine- don't hear much cracking or rusting.....
    I am going out of town this weekend but will post pictures as soon as i get back. It really gives a custom look to the pool to have the inside steps. I put up the walls and poured the collar. I then had a mason build me the desired steps out of concrete blocks and foamed over with 1/4 inch to protect the liner. The liner was custom made to measure. With my kit they bought the steps back. i put the credit toward the up charge of the custom liner. Increased the cost of the kit by about 200.00. Block and labor was about 400.00. Well worth it to avoid the white steps I think. When I get the cantilever coping/pavers in it should be hard to tell its vinyl.
    Just checking to see how that step install went and how the experience with Pool Warehouse was. We've put a deposit down on a 20x42 Mirage freeform polymer wall pool with them and we're looking at hiring an out of town contractor to install it for us.
    I'm interested in how you handled the concrete steps and if you hit any snags with the install itself. Our house is still under construction and we will be dried in by next week. We're looking to install our pool in October.
    Kash
    Flowery Branch, Georgia
    WE chose a steel wall pool by Kafko. This is steel wall even with all the curves.
Closed Thread
  1. Changing from steel to wooden walls?
    By Leehicks79 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2013, 05:37 PM
  2. SWCG for vinyl lined pool with steel walls?
    By windypool in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-20-2012, 11:54 PM
  3. How do ya'll like your steel/polymer wall inground pools?
    By georgiapoollover in forum In-Ground Pool Construction and Repair
    Last Post: 08-16-2006, 09:50 AM
  4. Polymer Walls vs Aluminum Wall IG Pool
    By poulsen11 in forum In-Ground Pool Construction and Repair
    Last Post: 07-28-2006, 11:16 AM
  5. galvanized steel vs. stainless steel
    By Sean-NJ in forum In-Ground Pool Construction and Repair
    Last Post: 07-20-2006, 07:05 PM
