Results 1 to 3 of 3
Thread: Pump/motor oddity
    Default Pump/motor oddity
    I switched off the pump to add tabs to the chlorinator. It was running just fine. Filled the chlorinator, switched the pump back on and ...nothing. Motor just hummed and tripped the breaker. Tried a couple of more times-same thing. Any ideas to hel pwould be appreciated. If I need a new pump, I'd understand. The pump is pretty old, but the motor is newer.
    Thanks guys ( and ladies).
    Hoosier56
    Honesdale PA
    Default Re: Pump/motor oddity
    Welcome to the forum.
    Here are a few links to this problem that have been discussed in the past. Check them out and if they don't help or you have any more questions don't hesitate to ask.
    http://www.poolforum.com/pf2/showthread.php?t=1680
    http://www.poolforum.com/pf2/showthread.php?t=764
    http://www.poolforum.com/pf2/showthread.php?t=141
    Thanks for the help. As soon as it quits raining I'll give it a hit.( I like that idea just on sheer principles). It's due for replacemnt anyway-I think it's about 16 years old. It came with the house and pool and I've been here fifteen years.
    Thanks again- Al
