Thread: Help me choose an Suction side cleaner?
    Default Help me choose an Suction side cleaner?
    Please help me choose a Suction side cleaner ?
    I am having an IG vinyl 17x33 pool installed and need to choose a suction side cleaner.
    The basic one that comes w/ the pool package is the Polaris 150.
    I have no idea if this use is worth a poo, but I like to get personal feedbacks on here from the owners that use a suction side cleaner.
    The other ones I can choose from are the following:
    1. HAYWARD NAVIGATOR
    2. ZODIAC BARRACUDA G4
    3. POLARIS ATV
    4. * POLARIS 150
    Help me choose the right one . So feedbacks would be appreciated!!
    Default Re: Help me choose an Suction side cleaner?
    Kinda curious about those Pool Rovers also
    I like my navigator on my pebble finish. It cleans the bottom and sides very well. I have found that it's sensitive to flow rate, not enough and it won't climb the walls. Too much and it can go up onto the baja shelf. I have a manual valve at the pump to control how much suction goes to the cleaner and this works well. I have had it for 1 year and the shoes are getting close to needing to be replaced. I haven't had any problems with it. In the year I have had it perhaps I had to lift it out of the pool two or three times total to clear a rock.
    -- john
    Rescue30 is offline ** No working email address ** Rescue30 0
    I had a Polaris 340, the older version of the Polaris ATV, I liked it more than the Baracuda G4 as I have a vinyl liner and felt the rubber pad of the cleaner just dragging across the pool would ruin the finish .Why don't you have them plumb in a booster pump line for a pressure cleaner , costs a bit more but I feel they do the job much better than the suction models , when the suction ones are installed you lose your skimmer action and if they are putting in a dedicated line for the cleaner , change it to a booster pump line instead.my humble .02
    Quote Originally Posted by Rescue30
    It's worth a shot to ask the builder. Lets see what they say. Thanks!!
    Tennessee
    I have a ZODIAC BARRACUDA 1500 and dont like. Hangs and you have to baby sit it.
    If your builder doesn't want to go with the dedicated booster pump line , ask him about a Polaris 360 which runs off one of the return lines.the biggest problem with a suction cleaner is all your dirt will go right into the filter requiring backwashing more frequently, a pressure cleaner or the Polaris 360 will put the dirt in it's own bag .
  1. Baracuda MX-8-No Side Suction
    By esco803 in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-24-2011, 06:41 PM
  2. Recommedations for suction side cleaner?
    By cscannon in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-15-2011, 08:00 PM
  3. Suction Side Cleaner - Q's & Opinions
    By rrands in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-29-2007, 08:02 AM
  4. Suction Side Air and leak
    By lcrooks in forum In-Ground Pool Construction and Repair
    Last Post: 05-13-2007, 12:02 AM
  5. suction-side cleaner or pressure-side
    By JShilling in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-08-2006, 08:58 PM
