Fog, it's your pool and you can do what you want with it, reguardless of what I or anyone else here tells you to do. Following the standard poolforum advice, I'll tell you to get a good test kit before adding anything to your pool. If you do and will post your
cl
tcl
pH
TA - (total alkalinity)
ch - (calcium hardness)
cya -(cyanuric acid-or stabilizer)
Lots of people here will jump in and tell you exactly what and how much of all chems to add to your pool. If you have a vinal pool, you don't need the calcium that your 'sock-it' will add, but you'll need to take it into account when adjusting the chemistry in the future.
It's a tough concept for us Americans to deal with, but only add what your pool needs, in this case more isn't necessarily better.
Good luck with your pool, and know that the members of the poolforum are here to help if you need it!
