Re: Can find cause of all the dirt/sand in the pool
The only thing I can think of is vac to waste. If you don't have that on your filter I've thrown the hose over the side of the pool and used the vac to siphon the fine sand out.
I swear I used to get more fine sand problems when using granular chlorine.
Not having enough sand in the filter is a possibility too - make sure it is approx 2/3 full.
