Sounds like a seal problem on the filter. If air was entering at the pump it would most likely get sucked right through the filter and not accumulate in the top of the filter.Originally Posted by Madty
Is this a multi position filter like a sand filter? If so, you may need to replace the gasket up there. Did you store it with the lever between two positions? If not, you could have caused memory in the gasket and could be drawing air throught the waste port.
Wayne
