Results 1 to 10 of 12
Thread: New pool cloudy water???
    Sanford, FL
    Default Re: New pool cloudy water???
    What is your pool store using to test the PH? Either you or the pool store is doing something incorrectly to get such different results.
    If the pool store is using strips it will be inaccurate.
    Did you let your wife test the water at home with the test - maybe you are doing something wrong when you are testing?
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Jul 2006
    Morris Il
    The pool store is using strips and I am using a 6 way test kit. The pool cleared up until I hooked up the heater (was given to me) and cleared the pipes on heater so it should clear back up today.
  1. HELP, cloudy blue pool water
    By krschaefers in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-25-2012, 05:02 PM
  2. Cloudy Pool Water - Could use some help
    By bcooper27 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-05-2010, 03:43 PM
  3. Surprise ... Cloudy pool water
    By uwinsome in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-03-2009, 02:06 PM
  4. opening pool, cloudy water
    By dalejanus in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2007, 08:20 PM
  5. Need help with cloudy water in brand new pool
    By Jeffski in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-11-2006, 03:05 PM
