Results 1 to 10 of 14
Thread: how much shock is too much?
Threaded View
  1. #7
    Default Re: how much shock is too much?
    1 gallon of ultra bleach will raise 10000 gal approx 6 ppm
    1 gallon of regular bleach will raise 10000 gal approx 5.25 ppm
    Call your pool 20000 gallons to make the measurement easier so I would add enough to keep the pool at about 12-15 ppm until the algae is gone.
    another way to look at it is 2 oz of ultra bleach will raise 1000 gallons about 1 ppm so every 36 ounces (call it a quart to make it easer) will raise your pool just about 1 ppm or slightly less.
    These are approximations but should be close. Test the water and make adjustments accordingly.
    Hope this helps.
