Closed Thread
Results 1 to 10 of 23
Thread: Adding DE to sand filter
    Mandeville, LA, USA.
    Default Re: Adding DE to sand filter
    Raddish, I'd open up the filter and check the condition of the sand. You may well have some chaneling that is allowing the DE through the sand.
    Also, what size pump and filter do you have? What is the normal (freshly backwashed) pressure at the filter?
    Rocket City, AL, USA.
    The pump is a brand new (less than a week old) Pentair Dynamo 3/4hp two speed pump. I added the DE while the pump was on the high speed setting, and left the pump on high for the 12 hours or so following the introduction of the DE. Even after the pump was set to low, there still remained a lot of particulate matter that could be seen in the pool light.
    During the daytime, the pool water does look crystal clear. The only time I can see any particles in the water is when it flows past the light at night.
    The filter is a new (installed in early June) Hayward 220T with new filter sand.
    I had just backwashed prior to introducing the DE to the filter. The normal pump pressure is 9.5 psi on the high setting.
    Not sure what is going on...unless you don't have sufficient sand in your filter (must have at least 200#). It sounds like you may have a cracked lateral, or the sand isn't distributed correctly.
    In any case, I don't think it's a DE problem but the DE blowing out is merely a symptom of a much deeper problem.
    Okay, I decided not to backwash and let it go a couple of days to see what would happen, and last night I noticed that my water was clearer than it has ever been. There was virtually no particulate matter to be seen in front of the pool light!!
    I guess the DE trick does work, and perhaps I just introduced it to the filter too fast or something. At any rate, next time I backwash I'll go a little slower with the DE and see how much I'll need to get the job done.
    Jul 2006
    Hot, Dry Texas!
    Does this work with Zeolite sand also?? I have a cloudy pool trying to clear up, my neighbor gave me some DE and I want to try it, but don't know if I should...
    18' round AG Money Pit( till I found this place!)
    PoolMom,
    I've been running with some DE in my zeo-something filled sand filter for the better part of a year now with no ill effects. That's the good news. The bad news is that I see little if any positive effect from adding the DE. My water is very, very clear, but at night I still have visible particles in the light field, with or without DE in the filter.
    I will say that I get a faster pressure rise in the filter when I have DE in it. It's obviously catching more stuff, but it doesn't seem to make a bit of difference in the visible water quality.
    Honesdale PA
    Raddish,
    Since you have a 2 speed pump, given a choice, I'd try adding the DE while on low speed. You want it to form an even layer on the top part of the sand and it seems to take a while to layer the sand. The 15-20 minutes mentioned. Also, haven't seen it mentioned so far in this thread, but you should pre-mix the DE in a few gallons of water and pour it in the skimmer slowly. I even think they say this on the DE package.
Closed Thread
