Thread: Question for "down the road"
    Jul 2006
    Corinth, TX
    Question Question for "down the road"
    I am planning to change from Baquciil to the BBB system. I have ordered the test kit from Ben and will start the conversion when it arrives.
    Once the conversion is complete, and my numbers are correct and stable, what maintenance is involved to keep it right.
    Do I add pucks in a floater to keep levels up? How often should I test? I live in texas and it is hot and sunny all the time, does that make it worse? Thanks in advance for your help.
    Dan
    18 foot above ground vinyl lined pool. The pool has an expandable liner that drops to 5 foot deep for about 9000 gallons of water.. It is surrounded with a raised deck about 1/3 of the way around the back of the pool.
    Indiana.
    Default Re: Question for "down the road"
    If you use pucks, you will have to keep an eye on your CYA. That won't be a problem at first, because you will need some to make your chlorine hold through those hot, sunny days. I just add a little bleach in the evening when I get home from work. Takes maybe 2 or 3 minutes to test for chlorine and add what it needs. Good time to drink a nice cold beverage .
    Dan:
    Go to the following three topic categories:
    Chlorine....
    Testing...
    Problems...
    then read the stickied posts at the top. They should help answer a lot of your questions.
    Good luck!
