Thread: lowering alk w/ already low PH
    Default lowering alk w/ already low PH
    Can you safely use Bens method if your PH is already pretty low? Here are my numbers from this morning:
    TC - 3
    PH - 7.2
    ALK - 280
    Hardness - 410
    CYA - didn't register, water wasn't cloudy, black dot never disappeared
    Pool is newly built so we only started with chemicals yesterday. Shocked pool yesterday with one bag of shock (68% cl) that said it's good for 10,000 gallons (which is what we have ~ 15x30 oval with 46 inches of water).
    Main goal is to lower alkalinity (which is from my well water so any water that I add will be high alk). Used 2 cups of muriatic acid yesterday (1 cup at a time about 4 hours apart). Have been running the return on top of the water to aerate. No change noted.
    Any ideas?
    Default Re: lowering alk w/ already low PH
    It's best if you keep a question only in one thread--it makes it less confusing for the responders and keeps from cluttering up the forum any more than it is. I answered this one in your other thread.
    On the other thread, someone suggested that I post on the correct forum (alkalinity forum) and since I can't move my own post, this is what I thought was best. Sorry.
    GTakacs is offline Registered+ Thread Analyst GTakacs 0
    On my 12,000 gallon pool I started with an alkalinity of 370 and it's down to 130 after 4 days of constant aerating with a 12 ft long 2 ft tall cascading waterfall, two deck jets and a foam jet in the beach entry. My pool also has eaten 5 gallons of muriatic acid in the process.
    I think your problem is the aeration, or lack thereof. You need to really move that water around and out of the water to get some good air in there. You can lower your pH even more (a cup should bring it down about 0.2 on the pH) and jsut keep an eye on it.
  1. Lowering TA.
    By DennyB65 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-16-2011, 01:03 PM
  2. Lowering CYA
    By jrsdws in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-21-2011, 05:39 PM
  3. Lowering pH with CO2
    By Jakebear in forum The China Shop
    Last Post: 09-12-2006, 01:21 AM
  4. Lowering Alk
    By Simmons99 in forum Dealing with Alkalinity and Calcium
    Last Post: 08-29-2006, 06:21 PM
