Thread: Confused by Pool store analysis
    Jul 2006
    Hot, Dry Texas!
    Default Confused by Pool store analysis
    I took my water to the pool store today to see where I am with CYA AND stuff
    Tot Cl-10
    Free Cl-10
    CYA-85(was 181 6 days ago)
    Ph - 8.2( however according to my taylor kit from Leslies, it's 7.4)
    Total ALK- 112( was 160 on my test kit this morning)
    They want me to lower my PH and raise my alkalinity but I am thinking no, what do you think??
    Default Re: Confused by Pool store analysis
    Did they use strips, or the computer method, or drops? If you're testing with a drop-based kit, and I'm assuming you used the Taylor kit for all your testing, then I would go with your numbers and stop playing around in the pool store. I don't remember offhand what type of pool you have, but if it's a vinyl pool with a pH or 7.4 and a TA of 160, I'd leave it alone!
    Jul 2006
    Hot, Dry Texas!
    Thanks, the pool store uses the strips in the computer, I used the Taylor drops kit, my pool is a 18ft ag round vinyl. I will just leave it alone for now and see what happens. Is my CYA ok, or should I drain and refill??
    I'd go with your test numbers over the pool store's anyday.
    Regarding your CYA, some people would tell you to refill--I personally prefer higher CYa levels. It's really your choice--just be aware that if you don't drain/refill, then you're going to have to keep your Cl at no less than 5 ppm at all times...
    Jul 2006
    Hot, Dry Texas!
    How much should I drain and refill??
    The reason the pH was reading so high is that chlorine levels above 10 ppm will cause bogus pH readings, whether strips or drops. They all use phenol red indicator! The only way to get an accurate reading when the chlorine is high is with a properly calibrated pH meter (and even that can suffer from some interferance!) The Taylor reagent is good up to about 15 ppm chlorine. LaMotte and most strips don't read pH accurately above 10 ppm and most cheapie kits don't work very well with chlorine above 5 ppm!
  1. Pool Store selling "bleach", or the pool store blinked!
    By Spensar in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-02-2013, 11:01 PM
  2. Difference in Water Analysis
    By gfritz1 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-24-2013, 07:59 PM
  3. My new pool to open on 6/25...here is the "store's" water analysis.
    By Machster in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2012, 11:51 AM
  4. percentage of hydrochloric acid, hardware store vs. pool store
    By dhanger in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-21-2011, 02:45 PM
  5. Pinpoint Computerized water Analysis system?
    By josh172 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-22-2006, 08:42 AM
