Results 1 to 8 of 8
Thread: Sta Rite equipment good?
    Default Sta Rite equipment good?
    How good is the quality of Sta Rite equipment verus jandy or hayward?
    It seems my builder for my IG vinyl pool is Sta Rite equipment. So I figure I ask. Thanks
    mas985's Avatar
    Pleasanton, CA
    Default Re: Sta Rite equipment good?
    I think Sta Rite is of similar if not slightly better quality than some of the others. However, when I built my pool, they did not offer an extended warranty for buying multiple items. This is the reason I did not go with Sta Rite. Otherwise, I probably would have.
    Mark
    Starite is owned by Pentair. Their quality is very good.
    my starite sand filter and pump are both at least 10 years old..and i know the prior owners did as little as possible to maintain them.when we bought our house 4 years ago, only thing i had to do was i cleaned out the filter of some gunk..otherwise, i religously clean out the trap basket, backwash and rinse once a week..no problems..i would buy their stuff again if the quality is as good as these were.my furnace on the other hand is the original (1983) hayward. i think it's going south as for the first time since we've been here, sometimes when it fires it up it belches about a 1 to 1.5 foot flame out the front for some reason. i suspect something is rusted out..but the thermostat etc is working fine..i may get a starite heater given my luck with the rest of the stuff next year. on that note, if anyone has any ideas on what the flame is about, let me know i want to get through this season anyways..and there is no smell of natural gas before this happens so it doesn't appear to be a leak persay but...
    The pump I will be getting is the Dura-Glas, which seems to been around since dinosaur time. So I assume this will be a extremely relaible pump, right?
    Yes I am a newbie
    Grecian 17'x33' Vinyl liner pool
    ZeoBrite filteration
    SWG Aqua-rite
    Sta-Rite Dura-Glas 1.5hp pump.
    SAM Light
    21037.5 gallons
    you won't go wrong with a duraglas. that is what i currently have..it's still running fine and it's been 4 summers for me and i'm guessing at least 4 years before that if not longer before i owned the house. it does not leak and only thing i've done on it is changed the lid because the gasket developed a crack (would have likely been fine if i lubed it with silicon spray but my understanding was it was permanently lubed. i suspect the gasket had been replaced prior and quite frankly, it would not have hurt for a 5 dollar can of silicone spray from napa to spray it once a season anyway)
    Southern Indiana
    I just replaced a Hayward 3/4 hp SuperPump II with a Sta-Rite MaxEPro 3/4 this season. Moves a lot more water and is much quieter to operate. The servicing looks like it will be much easier as the impellor housing is held together with a stainless steel quick release band. The inlet basket is much larger. The only downside for me was the extra work involved in switching to 2" lines, but I was installing an AutoPilot SWG at the same time and it is a 2" manifold (I also replaced my Multiport valve that was 16 years old with a 2" version).
    Also, I called Sta-Rite concerning a question I had about the pump before I ordered and was pleasantly surprised with how easy it was to get to talk to a real person and that person was knowledgeable and happy to assist me. Now its just a matter of whether or not the product holds up over time, but I will certainly look favorably at Sta-Rite for other equipment needs now.
    Saint Cloud, FL
    I have a Sta-Rite 1˝ HP pool pump and a Sta-Rite 1˝ Hp well pump, and apart from from having to repair the pool pump from a mistake I made, they have both served me well.
    Pat
  1. Aqua RiteŽ Jr. ?
    By BND in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-05-2007, 07:53 PM
  2. Sta-Rite heater
    By DONNIE in forum Pool Equipment & Operations
    Last Post: 11-30-2006, 07:36 PM
  3. New Aqua Rite
    By Simmons99 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-06-2006, 04:01 PM
  4. Aqua-rite Swg
    By DONNIE in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-31-2006, 09:01 PM
  5. sta rite system 3 cardtidge as good as de?
    By coryinsocal in forum Pool Equipment & Operations
    Last Post: 07-07-2006, 03:43 PM
