Re: Newbie needs advice....so confused
I would put in a metal sequester, then use bleach to shock your pool. Get rid of the pb - make sure you put in enough of the sequestering agent according to the size of your pool - that will bind with the copper that is in the water, so that it doesn't fall out when you shock. You will need to get some cya in the water, you can add it in the skimmer but you can't backwash the pool for a week, or you can put it in a sock and let it dissolve. With a cya of 0 you can take your chlorine up to 10 for a shock. Keep it there until the chlorine holds overnight, and be consistant - everytime it goes lower than 10, add enough to bring it back to 10. Test as often as you can and leave your pump running 24/7. They didn't test your calcium? You will need between 200 - 400 in a gunite pool, your ph and alkalinity are fine.
Northeast PA
