Leaking chlorinator in a new pool, suggestions?
Our pool (24' round 52" wall) was built back in April. Due to lots of fun times with electricians and builders, our electrical was finished only just yesterday. So we excitedly hooked up the pump...and then had to figure out how to work the breakers on the electic panel. OK, try number two, the pump works like a champ, but there's water pouring out all along the assembly.
The tubing goes from the skimmer basket (ball valve)-->chlorinator --> Nature2 --> DE filter-->pump -->back to pool. The water is practically gushing out the cap of the chlorinator and the Nature2. Tightening the cap on the Nature2 helped but we haven't been able to figure out how to tighten the chlorinator sufficiently.
Anyhow..having read the forum here for a few weeks, I'm definitely going BBB and I'd just as soon have the chlorinator and the Nature2 off the system. Is there a fitting that would allow us to just detach them and connect the two hoses? I'm not sure the hose that comes from the skimmer will reach.
This morning I sealed the chlorinator cap with silicon so I could at least run the pump on low.
