Results 1 to 10 of 13
Thread: Average Maintenance Costs?
    Default Re: Average Maintenance Costs?
    there are many available, most look like this:
    these are mine - on the ground, then there are some you can customize in size length to suit your install...like the links to these other threads
    http://img.photobucket.com/albums/v2...4/100_2895.jpg
    http://www.poolforum.com/pf2/showthread.php?t=3409
    http://www.poolforum.com/pf2/showthr...highlight=part
    WoW!! how in the heck are you guys only spending about 150.00 a year on the pump it-self?
    I been reading off garden web and the average joe is spending at least $80.00 more a month on it's electricity bill every month.
    I don't know, maybe b/c in NY or MI the summer is not as hot?
    Unless I mistaken this, I feel that I will be spending at least $80-$100 additional a month just on the electric due the the pump usage
    mkelley is offline Registered+ Thread Analyst mkelley 0
    That's certainly the case with me, Mike. I feel my electric bill is about $80 per month for the pump.
    However, recently I've lowered the number of hours it runs and I'm hoping to cut that in half. Let's say that's so -- then $160 per season would be correct for a four month pool season (quite often the case without solar).
    Before we bought the pool I understood the pump would be the biggest user of electricity next to air conditioning, and it's turned out to be the case. Then again, I have a 2 1/2hp pump (which apparently is overkill for our size pool).
    Perhaps if you correctly size the pump AND run it the proper number of hours to clean the pool without over running it, then you can keep your costs down.
