Results 1 to 10 of 10
Thread: Are SWG's illegal in California?
    beary is offline Registered+ Thread Analyst beary 0
    Dec 2005
    Default Are SWG's illegal in California?
    A friend of mine is building a pool and one of the builders' he interviewed said that salt water pools are illegal in California because salt water is considered a hazard to the environment. Illegal in California? He also told my friend that salt pools require coated rebar. All stuff I've not heard before. Interesting.
    beary
    mas985's Avatar
    Pleasanton, CA
    Default Re: Are SWG's illegal in California?
    Nonsense, I have one. The builder probably does not offer one or has never installed on. Or he may be thinking of a true salt water pool and not a SWG. The salt levels for a seawater pool are 10x that of a SWG pool.
    Mark
    duraleigh Guest
    Uh-oh! Arnold is gonna' drain the Pacific! There goes the budget again.
    North Florida
    Post Re: Are SWG's illegal in California?
    This topic came up on another internet site and here's a link that pertains to it. I guess this issue affected one area of California at that time...don't know if it's still in effect or if it has been passed in other areas. Other posters on the other site pointed out that it affected only those who have their systems draining into the sewer system and that the salt concentrations targeted in the law are usually not those of residential pools (which are lower).
    I'm not an expert about this, but this article should give anyone who's interested a starting point.
    http://www.allbusiness.com/periodica.../854201-1.html
    Sandy
    Dec 2005
    Kind of what I expected. Has there been any problems found to be caused by the salt in pools using SWGs?
    beary
    Ft Lauderdale, Fl
    The pool industry is fighting this action by Santa Clarita, Ca. Unfortunately LA was trying to follow with them. However, there is no basis for this conclusion as salt from a salt pool is minimal in comparison to the other sources of "sodium" being leached into the water system.
    It's not the salt being used in Salt Chlorine generator pools, it's the discharge from backwashing that they are concerned with.
    At this time, Santa Clarita is the only city that is preventing builders from installing salt chlorine generators on pool. Also banned are water softeners!
    Sean Assam
    in my city (Norco) water softeners that put salt back into the sewer system are banned. However I don't think SWG's are banned because many of the new pools have SWG's on them and the inspectors are very picky and wouldn't pass them if it was a problem.
    Oakland, CA
    Uh oh, does this mean that I can no longer put salt in my pasta water? :-)
    30'x16' (irregular) indoor gunite/plaster pool, 10k gal,
    Autopilot DLG-220 with SC-48 cell, 3/4 HP recirc pump,
    solar panels, heat exchanger from 200 kBTU/hour Viessmann boiler
    SoCalBoo is offline Registered+ Thread Analyst SoCalBoo 0
    San Diego
    What's the conversion on milligrams to ppm? Would 2000 mg/lit encompass all of our pools running in the 2500-3500 range?
    Mandeville, LA, USA.
    For water 1 mg/liter = 1 ppm.
  1. Winterize in Southern California
    By kirkinsd in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-27-2011, 07:53 PM
  2. Closing an IG Pool in California??
    By human in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-20-2006, 07:48 PM
  3. Baja Pools in California
    By INLANDSMOG in forum In-Ground Pool Construction and Repair
    Last Post: 09-01-2006, 02:00 PM
