Thread: How's my numbers
    Question How's my numbers
    AG Pool - 8,500 - sand filter
    FC: 2.0
    PH: 7.5
    ALK: 110
    CYA: 50
    We have been trying to "stabilize" the pool for three days now coming out of our "shock treatment". I'm already running out of some of my drops from my 6 way... can you buy the drops separately, especial the CYA... Don't have enough for another test.
    Sanford, FL
    Default Re: How's my numbers
    Generally you don't need to test CYA everday - as it will only change if you are adding it (through the use of pucks) or you drain the pool and refill. Someone with more knowledge of your test can probably answer where to purchase additional reagent.
    Completed 8/21/06
    14,000 gallon 3'-6' concrete pool with Diamond Brite
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Hayward Super II Pump - Cartridge filter
    See pictures here http://www.philsimmons.com/family/ga...mages&keyword=
