Thread: Just wait or add something?
    Default Re: Just wait or add something?
    Be patient and let the pump run. I'd add DE/sock also and next time you add chlorine, just use bleach. Bags of shock you're using adds calcium and can increase cloudiness.
    Jul 2006
    Hot, Dry Texas!
    Quote Originally Posted by day1
    I am so DONE with the bags of shock, but I just need to get the "remnants" of the last bags I added over the weekend... I am running the pump 24/7 and I am going to get a sock and try it, it def won't hurt anything will it?
    Mandeville, LA, USA.
    The sock won't hurt anything. Nor will the DE unless there's a problem with your sand filter (e.g. channeling in the sand that will let the DE through; something that you probably can't rule out at this point).
