Closed Thread
Thread: Just opened the pool... questions
    Dec 2005
    Corrales, New Mexico, USA.
    Talking Just opened the pool... questions
    So just opened the pool. AG...approx 19,000 gal
    Initial tests...
    CL-- 0
    PH-- 7.5
    Alk- 200
    Hardness- about 500
    CYA- 100
    I am on well water... Am switching to bleach this year. Emptied the feeder. Used the calculator and added 1 gallon of 6 % to bring to 3 ppm
    Water is a little cloudy. Running the filter now. What else should I do...?
    Default
    Quote Originally Posted by JMCFAN
    Initial tests...
    CL-- 0
    PH-- 7.5
    Alk- 200
    Hardness- about 500
    CYA- 100
    If it were my pool with high cya and high calcium hardness, I'd do a partial drain to lower both those values. Of course, that may not be an option for you if you are on well water. At any rate, if you want to try and not drain, be sure to use only bleach to chlorinate with. You don't want your cya any higher and you definitely don't want your hardness reading any higher. No cal-hypo for you. You may still have a problem with cloudy water with CH of 500. That is kind of the end of the acceptable range. Some people have problems with clouding at 500, others don't seem to. Time will tell. Keep running your pump 24/7 right now while trying to clear it and if you don't do a partial drain, you're gonna have to run higher than normal chlorine levels to adequately sanitize your water. See the sticky at the top of this forum "Best Guess CYA chart."
    Keep us posted how things are going.
    Watermom
    Dec 2005
    Default
    I did a partial drain and fill at the end of the season last year.... I can do it again. I can only seem to get it down past the skimmer and I lose prime..
    I use my vacuum and clean the bottom while I pump off into the vacant lot behind me
    I will go ahead and do another this evening... damn...3 years on pucks and now I am fighting this...
    What can I do to get the hardeness down...?
    Default
    If you want to get the water lower than the skimmer mouth, use the vac - (* if you're sucking air while 'vac-ing', put the other end of the vac hose in the skimmer) It sounds like the skimmer is your only suction source.
    I don't know (and apparently you don't either) if your fill water is the cause of your high CH - is it possible to 'truck in' some low calcium water?
    Dec 2005
    Unhappy
    Dont know.... could be my well water. It is pretty hard. I have to use "Metal B Gone" post adding fresh water or I turn my pool green..
    Default
    That sounds like copper in your water. Might want to check for that.
Closed Thread
  1. Just opened pool and trying to use BBB, am I doing it right?
    By naturegirl in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-20-2011, 06:12 PM
  2. Pool just opened, awaiting on testing kit, questions on what to do now
    By pool1 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-25-2011, 05:14 PM
  3. No kit yet -- Opened Pool -- What Should I do?
    By AnnaE in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-21-2006, 08:40 PM
  4. Just opened pool for spring, test result questions
    By Beachnut_PA in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-01-2006, 09:07 AM
  5. I opened up my sand filter and now have a couple questions
    By Crispyc21 in forum Pool Equipment & Operations
    Last Post: 04-12-2006, 11:45 AM
