Results 11 to 19 of 19
Thread: power setting on AutoPilot
    Ft Lauderdale, Fl
    Default Re: power setting on AutoPilot
    The Automatic Temperature Compensation adjustments run along this chart. These are not absolute values and may fluctuate +- 2-3 degrees.
    Sean Assam
    Caledon, Ontario, Canada.
    Thanks for digging this out for us Sean.
    Can you tell me the relative power settings at the different leves 1, 2, and 3 ?
    Ft Lauderdale, Fl
    Cell Power 1 = 5.0 amps
    Cell Power 2 = 6.5 amps
    Cell Power 3 = 8.0 amps
    Normal operating Volts depends on the cell.
    SC-36 = 16 - 19 volts
    SC-48 = 23 - 27 volts
    SC-60 = 21 - 26 volts
    when the salt is low, cell is scaled, water temperature gets colder, or cell is wearing out, the voltage will rise to 28-29 volts. At that point the amperage will drop. This is where you start seeing the warning lights appear.
    This is SPECIFICALLY for the Pool Pilot system. However, you'll see the same affects on the cell due to the same reasons.
    Sean Assam
    Great. Now I can understand where I'm going.
    Thanks a lot. By the way. Wave this message in front of the people that write your paycheck. The primary reason I bought the Autopilot Digital was your participation on this forum. At the very least you deserve a gold star!
    Ft Lauderdale, Fl
    Thanks Brent. I appreciate that.
    hmmm, if you noticed, I changed my "signature" to commercial sales from Technical Support. I wonder if my boss will consider this into my sales commisions.
    Sean Assam
  6. #16
    hzz is offline PF Supporter Thread Analyst hzz 1 star
    Toronto Canada
    I also bought the Autopilot mainly due to what was said about it on this forum and especially due to Sean's participation here.
    I am very pleased with the unit and Sean has always been there when I needed anything.
    Show this to your boss, Sean. Maybe you'll get a raise.....lol
  7. #17
    Ft Lauderdale, Fl
    Raise...yeah sure. I tried and instead, I get to go to Calgary in a few weeks for a one day round of golf.
    I think he will still let me take some time off to take the family to Tampa Busch Gardens afterwards though.
    :P
    Sean Assam
  8. #18
    Cedar Hill, TX (Dallas)
    one day of golf... you sales guys...
  9. #19
    Oakland, CA
    Thanks Sean, this is very useful!
    30'x16' (irregular) indoor gunite/plaster pool, 10k gal,
    Autopilot DLG-220 with SC-48 cell, 3/4 HP recirc pump,
    solar panels, heat exchanger from 200 kBTU/hour Viessmann boiler
  1. Setting up our new 16x48
    By rlmommy in forum Intex-type Pool Setup & Operations
    Last Post: 05-30-2013, 12:24 AM
  2. Pool Pilot Setting
    By DONNIE in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-07-2007, 05:45 PM
  3. Is my pool/ AutoPilot setting OK?
    By poolbee in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-02-2006, 11:13 AM
  4. Where is the waste setting?
    By bass9864 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-02-2006, 10:47 AM
  5. Rinse setting?
    By thilbert in forum Pool Equipment & Operations
    Last Post: 04-08-2006, 05:18 PM
