Re: Brown to green to ?
First add some baking soda, you need to get your alkalinity between 80 - 120 and your ph up to 7.2. Add baking soda and wait an lour and retest. If your alkalinity is ok, but your ph isn't up to 7.2, then add some borax, it will raise the ph without raising the alk. Right after adding the baking soda you can add regular laundry bleach - using cal hypo seems to react more with iron, so I stay away from it. You can find out how much to add with the bleach calc. Get your chlorine up to 2ppm. Add some stabalizer, enough to get it up to about 30. Once you get all of your numbers up it is ok to swim. You want your numbers to be
FC 2 - 3
CC 0
PH 7.2 (with iron in the water don't let your ph get above 7.4)
Alk 80 - 120
CYA 30 - 50
HOpe this helps, ask any questions you may have. Welcome to the forum. You can go to the pool solutions web site and read "pool care tips" it will help you to understand how to take care of your pool the easiest way. Just ask if you don't understand anything!
Northeast PA
16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
