First off, praise to this site. I've recently purchased a house with an pool, and had ABSOLUTELY no idea what to do with a pool (other than jump in and swim).
This past weekend we had a weekend long get together with a huge swimmer load for 3 days. I had been maintaining my chemistry, but wasn't prepared for the sudden increase swimmer load combined with rapid increase in sunlight and temp.On wednesday I got the dreaded green hue to the water. Not bad, but noticable to me. The water did not cloud up, but was starting to get green.
Well, I've been following the forums advice for killing the algae. And it has worked. I've been maintaining my chlorine at 15-20ppm (dropped to 11-13ppm once or twice), testing chlorine three times daily, brushing twice daily, followed by vaccum and then backwash filter.
Well, after a day and a half the water is clear and no green hue again, which is good. Tells me I'm on the right path. The one concern I'm having is that today from the 2pm chlorine test to the 7:30pm chlorine test I was STILL loosing 5ppm of chlorine. This is telling me that I probably am still battling algae.
My question is, when do I stop maintaining the 15-20ppm shock level and let the pool chlorine level reduce to a normal usable level??? Do I stop shocking since the water is clear and not green, or do I go by what my chemistry seems to be telling (that the algae is still eating the chlorine) and I need to maintain the shock level till the chlorine level does not drop 5ppm in a 5 hour time period. Or can I assume that the 5ppm drop is due to having a higher chlorine content and increase exposure to sun (cover has been off since I started shocking) causing a faster chlorine burnoff?
Thanks for all your assistance.
Chemistry
FC= shock 15-20
CC= 0
TC=shock 15-20
alk= 120
pH=7.8 (was mantained at 7.5 before the shock started)
CYA= 50
temp=78
24K inground pool, hayward sand filter
Another question about the pH. My pH had been very stable at 7.4-7.6. Once I started the shock wednesday nite the pH jumped to 7.8 and had been holding there. I added 4oz of muratic acid tonight, but haven't tested the pH since adding. Should I have left the pH alone?? Will it come down on it's own after the shock is over??
Blessings,
TRHOD
