that is what I came up with but wanted a second on it. Do I add the bleach through the skimmer or into the pool?
You can do either - pour slowly into the skimmer or pour slowly in front of the return jets. I wouldn't suggest pouring it into any part of the pool that gets less than adequate circulation.
IG 30,000 gal vinyl
About how long can I expect a green pool to take to get clear using the BBB method??
Keep the chlorine levels at 15ppm - 20ppm until the pool totally clears. When the algae dies you will have a blue cloudy pool - keep the chlorine high until it is no longer cloudy. Run pump 24/7 and backwash (or clean cartridge) frequently. If you test 3X a day and raise the chlorine level and don't let it yo-yo too much it will kill it quicker.
How long will depend on a consistant high chlorine level and how much stuff it has to kill in your pool - might be one day might be 4 days or longer.
Completed 8/21/06
Spa with spillway
250K BTU gas heater (for spa)
SWCG - Aqua Rite
