Results 1 to 10 of 27
Thread: Need SOOOO much help!
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Default
    To raise both PH and Alkalinity at the same time, use Arm & Hammer Baking Soda. You can get it in 4 pound boxes at the grocery store and 12 pound bags at Sam's Club, Costco, etc. There is a dosage chart on the box. As for what your levels should be...I have a chart at home that I made up using various information from this board & Pool Solutions (PoolDoc runs both sites). But, I'm not home right now...I'm at work.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    duraleigh Guest
    Default
    Loretta,
    Please don't get mad at this answer....even tho I don't think it's what you want to hear.
    If you download Mwsmith2's calculator from any of his posts it'll tell you how much to add of the different stuff...depending on where they are now.
    That said, how will you know where they are now without a test kit? Those pools store numbers are too old to be useful. I'll say it again, every post in your thread will simply be an arbitrary guess until you find a way to post your current numbers.
    Next, how will you know when you get to where you need to be? You need the test kit and then we will all work hard with you to get your water sparkling!!
    Dave S.
    Default Re: Need SOOOO much help!
    Quote Originally Posted by duraleigh
    Loretta,
    Dave S.
    Why would I get mad? Those test numbers were from the day I posted them so they may not have been up to the minute, but as quick as I could post them. I downloaded Michaels calc and it just tells me how much bleach to put in.
    What I need to know is where can I find out how to raise or lower my other levels other than chlorine to get them where they should be? Or does the bleach just balance everything else out?
    There are more options in the bleach calc if you go up to the menu bar...
    You can calculate how much to add for Alkalinity, Calcium Hardness, pH, Cyanuric Acid (CYA/Stabilizer/Conditioner), Salt, etc. Under Settings you can set it to save your pool capacity, what bleach/liquid chlorine strength you generally use and whether you prefer US (Imperial) or Metric units of measure.
    Sherra
