Thread: Dumb mistake - dumber question
    Miami, Florida
    Default Dumb mistake - dumber question
    Hi - hosted our first swimming happy hour yesterday after 3 days of terrible rains. Lots of friends, good food and drinks! After the party, my Cl was down to 3.0 and Ph had crept up to 8.0+ (new pool/LOTS of rain over 3 days).
    After the party, I was not myself apparently and I misread the bleach calculator. Added a jug of acid - I'm ok there. But in trying to bring my Cl up from 3 ppm to 6 ppm, using what's left of chlorine from when I was "pool stored" I input 10.5% as variable. I should have used approx 1 qt chlorine, instead used 1 gallon (DUMB MISTAKE!) This morning, numbers are:
    FC 11
    CC 0
    Ph 7.2
    Alk 60
    CYA 50
    CH 350
    Not really shock level at my CYA level per Ben's chart, just high Cl. Is there a downside to not "truly shocking"? Can that create a problem? (DUMB ? #1)
    More importantly to my kids - can they swim? (DUMB ? #2)
    Gracy
    16,725 gal gunite pool/1000 gal spa;exp agg finish; Jacuzzi 2 hp pump/Hayward cartridge filter/electric heater; Taylor K2006 Test Kit
    Default Re: Dumb mistake - dumber question
    You are FINE! Nothing to worry about...just put the kids in older suits, not their newest ones.
    That's about all you need to concern yourself with.
    Miami, Florida
    Thank you sir.
    Gracy
    As Carl said, no problem. If you want to bring the cl down a little quicker, let the kids out to run and play and tell them that it's ok this weekend not to rinse off before using the pool.
    Quote Originally Posted by waste
    ...tell them that it's ok this weekend not to rinse off before using the pool.
    BLECCCHHHH!!!!!
