Results 1 to 10 of 11
Thread: What are teses tiny rust-like stains?
    Default Re: What are teses tiny rust-like stains?
    Table salt should NEVER be used in a pool. It contains an anti-caking agent (yellow prussiate of soda) which is a iron compound. Only use pool salt, solar salt, or water softener pellets that don't contain iron removers or water softener tank cleaners that are at least 99.5% pure salt!
    NY
    It was the builder that added the salt. They told me I'd probably see these little satins and not to worry about them. My steps now have a large amountof these little specks all over them.
    What should I use to get the metals out? I saw Jack's Blue stuff-I have a SWG and a heater, the purple stuff is not for heaters as I recall. Is there a better formula out there and what is the proper way to do it? I really don't trust the pool stores to know.
    one other thing-when trying the vit. C does the strength matter? I used 250 mg. tabs and results were OK, but better than with cal hypo. Do I need stronger tabs?
    mbar's Avatar
    Ashland, PA
    If the vitamin C tablet worked, then it is metal stain. If the cal hypo worked, then it is an organic stain. If it is a metal stain, you can either use ascorbic acid (which is vitamin C), or oxallic acid. I use the ascorbic. Since you only have a few spots, I would try lowering the ph down to 7.2 and adding a sequestering agent like sequasol, jack's magic the pink stuff, or blue stuff, Metal free, any thing that say holds metals in suspension. Try this first - sometimes it will lift off stains that have just started. If it doesn't work, you can then do the ascorbic acid. You can get it at:
    http://www.msm-msm.com/store/agora.c...scorbic%20Acid
    or:http://www.chemistrystore.com/Ascorbic_Acid.htm
    Northeast PA
    Quote Originally Posted by poolbee
    Where did you hear that? The technical secton of the Jack's Magic website (for industry professionals) makes no mention of not using the Purple stuff with heaters. They recommend it for any pool with high TDS, which is what a salt pool is.
    I would be interesed in where you got the info on the Purple Stuff?
    NY
    I said as I recall. I have been reading up on so many different things I am probably confused. That's why I come here to seek advise, so I don't have to trial and error it. I am definitely not giving out any advise as I am absolutely no expert. I think I may have honed in on the Blue Stuff as it says it is for pools with heaters and dismissed the Purple as not because it doesn't specifically say it is. I guess I assumed and you know what they say about assuming...
    Anyway, I do have a SWG so the Purple Stuff would be the best bet for me?
    The reason the Blue Stuff says it's for pools with heaters is that most heat exchangers in heaters are copper and the Blue Stuff has a high chelation index for copper. The purple stuff is for pools with high TDS which include all saltwater pools.
