Thread: Feedback needed on first results
    Fort Worth, Texas
    Default Feedback needed on first results
    Received my PS234 today and tested:
    FC 4.5
    CC 1
    TC 5.5
    pH between 7.2 and 7.5, probably 7.4
    Alk 130
    Cal 300+ (I quit after 30 drops -- no change -- little pink globs swirling in the sample...???)
    Cya 55
    Pool specifics are in my sig.
    TIA,
    BGray
    B Gray
    28,000 gallon IG gunite pool
    Pentair cartridge filter
    Fort Worth, TX
    Default Re: Feedback needed on first results
    Shock with bleach to 20 ppm, then see if you have any CC. If not, you are done.
    Re-check your calcium. Recommended numbers for concrete/plaster pools is 200-400ppm and you only got to 300. As lono as it's in that range you are FINE, but higher is a problem.
    Alk is technically a tad high but I wouldn't worry--it's only 130.
