Results 1 to 10 of 12
Thread: Is it only Dolphin Dynamic's with the problems?
    Sun Prairie, WI
    Default Re: Is it only Dolphin Dynamic's with the problems?
    Poolbee,
    I just got a Pool Buster for spot cleaning, I get a few centipedes, earwigs, and the occasional spider daily, I had been fishing them out with a leaf rake (ugh). I have only used it a few times, but it works great for that.
    It won't do my whole pool (20x40) on a single charge though. But that isn't why I got it.
    ~Dr. Spike
    Pool: IG vinyl, heated, fully enclosed (dome)
    Shape: Grecian (rectangular)
    Size: 20'W x 40'L
    Depth: 4' / 8'
    Filter: Sand w/DE added
    Other: 6' Diving Board
    Maintenance: BBB! Ben's PS234 kit! Manual vacuum, brush, and Pool Buster Max CG Gold
    I hate to contribute to the thread hijacking but I got my Poolbuster last week and it's great for spot cleaning. Wouldn't want to use it for the whole pool and it really needs a finer filter for sand (available for extra cost) but other than that it works wonderfully.
    I usually put my Dolphin in at night but by the time morning rolls around a number of bugs have managed to crawl their way into my pool. I take 2 minutes with the buster and it looks great.
    NY
    Hey, hijack away! I started the thread and I don't mind-I asked the follow up question too!
    I am really thinking of gettting the Poolbuster or something similar. Often between swims on the same day stuff accumulates on the floor and the Poolbuster would do the trick.
    My poolbuster is wonderful, too--right now my Polaris is being rebuilt, and the Poolbuster is cleaning the whole pool--18 x 36 IG. usually not too much stuff in it, but when DH mows the grass, sometimes I think he points the thing directly at the pool!! It's the best money I've spent on pool equipment yet
    Quote Originally Posted by Dr. Spike
    Poolbee,
    If it's still under warranty contact them immediately! You have a bad battery in your battery/motor pack.
    They should replace it for free. If you're moderately handy, replacing the pack takes about 30 minutes, if they send it to you, rather than having you send the unit it. It should EASILY vacuum your entire pool on a single charge with plenty left over. You may not be using it for that but the problem will get worse.
    I went through that. I think I was the first to try the PB, and loved it--still do. But I complained that battery life was short. Finally, after 2 years, I called them--they couldn't give me a new battery since the warranty was a year dead, but they tossed in an extra charger since I had misplaced mine. I was really sorry I hadn't taken care of it under warranty--the battery/motor (which is the guts of the thing) was $79.
    Was it worth it? Darn straight it was! The PB is like a different animal--like it was super-charged! And I have yet to have it run out. With the old pack it did a good job, but if I didn't watch the charge, it would be dead when I needed it.
    PoolBuster svc told me that isn't right--and they were right. I can't complain about them--they did fine by me. So call them and get it fixed! You'll be glad you did.
    I also got the finer filter and it's terrific. They sell additionally paper filters that are disposable and even finer but I have found no need for them..
