How much GPM is my pump producing?
I have a 2 1/2 HP Sta-rite Maxi-Pro pump and can't find information anywhere on it that says what the GPM is -- only the RPM (even on the web -- I can find stuff like this page:
http://www.topdog.web.aplus.net/Merc...PUMPSAND-1-STA
which is close although my own pump is 1/2 HP larger)
I'm trying to figure out how long I need to run it each day but without that info I don't know if it's possible.
Re: How much GPM is my pump producing?
You need two things to determine GPM, head loss and the pump head curve. The pump head curve you can find in your manual or here:
http://www.poolplaza.com/Max-E-Pro-techspecs.shtml
Head loss is usually between 45-65 ft of head which means your flow is between 110-135 GPM. Your probably near the lower end given the size of the pump (higher head). If you want a better estimate then you need a more accurate head measurement.
Total Head = Return Head + Suction Head
Return Head = 2.31 * Filter PSI
Suction Head = 1.13 * Pump Suction (in. mg.)
If you can't measure suction head which requires a vacuum guage, use this formula:
Total Head = 3.2 * Filter PSI (assumes suction is 40% of return head)
2 1/2 HP seems excessive for a circulation pump. Your turnover will probably be less than 2-3 hr.
Thanks, Mark. That helps a lot.
Yeah, I know the pump is oversized -- even the solar guy was amazed at how big mine was (so to speak :>). It was just what they put in.
I had figured with 40 GPM it would turnover in six hours, so your estimate of 2-3 hours is probably right on the money. What I *don't* understand is whether I should be running the pump that little -- something doesn't seem right.
So... I guess my next question is whether if turnover is 2 to 3 hours, is it actually possible to run a pump that little? Is there not some sort of minimum time a pump needs to run regardless of the GPM, or is this just simple math and therefore that's it (I should also mention our water is always sparkling clear -- but I *was* running at 8 hours per day and then cut it down to 6).
First, let's get the details so we can narrow it down some.
What is your filter PSI? Pool volume?
To fully clean the water, you should not need more than 2 turnovers, Based on turnover, you can run the pump that short of a time for filtering but other things could drive you to a longer run time such as skimming the surface, solar or chemical distribution.
let's step back for a sec..i have a starite pump and the plate that has rpm on it has the max gpm on it. (i.e. mine says 48gpm for 3/4 hp pump) ...also, the other huge variable is the size of your fittings. i can tell you right now if you have 1.5 inch fittings, maximum gpm you will be able to run through it regardless of pump horsepower is 44gpm...it's simply as much volume of water you can push through pipes that size.
i have only the pool to pump (no spa) and 1.5 fittings so really, the 3/4 hp is perfectly mated at maximum 48gpm rating.
Tenax,
I know you mean well but the flow rate can exceed 44 GPM in 1.5" PCV pipe. In fact there is no physical limit on GPM given enough HP there is only a PSI limit where the pipe will fail. The specs for maximum flow rates are to prevent long term damage. This is why you will see older pools that have high HP motors with leaky plumbing.
